ilovesocks
- Jan 11, 2005
The M-Audio Firewire Audiophile is an external sound device that runs off (gee!) Firewire. It has a built-in headphone amp for the 1/4" headphone jack in front, a stereo RCA input, two stereo RCA outputs, one MIDI in and MIDI out, one S/PDIF coaxial in and out, and two Firewire jacks (the second one is for linking multiple Firewire devices in a row). If it is used with a 6-pin Firewire jack, it does not require the included AC adapter. The coaxial is nice for someone who wants to go DAC -> amp.
The driver CD that came with the Audiophile when I bought it six months ago had outdated drivers, so I downloaded the current ones (in the form of a 5.54-mb .exe file) from M-Audio's website. It is much easier to install the drivers from the .exe file than the CD; all you have to do is run the file (it says to do this before plugging it in at all, but I just plug it in and leave it off). It will install software and then tell you to shut down your computer and plug it in. I simply reboot and press the power button (a fairly solid spring-loaded one) while Windows is loading. New hardware will be detected; set it to automatically install drivers and it'll find the .exe file again by itself do its thing. This happens twice, and you're done! Now I just leave the power button on; the Audiophile shuts down when your computer shuts down and comes on when the computer boots up (if you're not using the AC adapter). I've never had any software compatibility problems running Windows XP Pro w/ SP2.
The control panel shows up as a red circle in the taskbar and is versatile and very easy to use. The Level Controller (right-hand, larger knob) can be assigned control pretty much any combination of levels (as long as they're under the same bus: software return, input, output, aux). The headphone volume knob (left-hand, smaller) can have two presets (A and B) for which the source-toggling button (the other metallic spring-loaded button) can switch between with a push. I have the Level Controller control the volume for my speakers on outputs 1/2, and simply use the headphone volume control for headphone volume!
The Audiophile is obviously quite handsome, and the nicely-colored lights are bright. The build quality is good, although the gold RCA and coaxial jacks on mine had bits of rust right out of the box. I didn't really mind though, since I use it exclusively for headphone/speaker listening. I picked the Firewire model over the USB model simply because it was better looking (metal instead of plastic) and I could get it for only $5 more than the USB model from the eBay retailer I got it from (I paid $135 - way below any other seller's price, not to mention the $350 MSRP!). My one quirk with it is the fact that the control knobs do not turn smoothly; they have bumped levels. I don't know how to describe it; hopefully you know what I mean. So sometimes when I want to turn it a notch in one direction, it detects it as a notch in the other direction, and sometimes I'll have to turn it two notches in order to get any change in volume. I could fix this by going line-out to my Go-Vibe, but I'm simply too vain.
Sonically, the Audiophile sounds great IMO - more bass than my Zen Micro - Go-Vibe combo. I play 320 kbps mp3's in foobar using ASIO, no DSP's at all. I don't have anything to compare it to, but cranking the volume all the way up doesn't produce noise, and the amp easily powered a pair of K240M's when they passed briefly through my hands. I keep the software return nearly all the way up; getting the right volume from the amp requires about 1/8 of the maximum.
All I can really say about the Firewire Audiophile is that it looks nice, has a decent interface, and has a pretty strong headphone amp (dunno about quality but it sounds good to me!). The only downside I can think of is the notched level knobs - I was really hoping for a smooth knob with a good amount of resistance. I plan to hopefully get a CIAudio VHP-1 someday ..
_________________________________________
PROS:
Affordable
Looks good
Reliable (no compatibility problems/malfunctions)
Bus or AC adapter-powered
Coaxial in/out
CONS:
Notched volume/level knobs
