M-Audio BX5a or Audioengine A5?
Jun 23, 2009 at 1:39 AM Post #31 of 45
Originally Posted by Nonchalance /img/forum/go_quote.gif
On a related note you can get 10% off of your Audioengines with coupon PBC10 if you order from the site.
You can get 25% off with mw09. Just verified that its still active. My A5's cost me $261 brand new.
Originally Posted by j3ff86
Slightly off topic but I have a question for A5 owners as I see there are a lot in this thread, how do you switch between them and headphones? I will have mine hooked up to a sound card (asus xonar) in my computer.
I have the Asus Xonar STX and A5's... I use the RCA outs for the A5's (you'll need an RCA--->1/8" adapter cable) and the headphone jack for headphones. I use the Asus software to choose where I want my sound outputted.
Jun 23, 2009 at 1:43 AM Post #32 of 45
Originally Posted by Ham Sandwich /img/forum/go_quote.gif
That should be plenty of space behind the speakers. I ended up putting 4" thick ATS Acoustics panels behind my BX8a monitors to tame a slight bass bloom because of the rear wall.
Did it eliminate the bass bloom? I am considering something similar. My A5's are about 6" from the wall.
Jun 23, 2009 at 3:28 AM Post #33 of 45
I noticed that the other day - nice discount. The BX5a's mentioned here are now going for $269 at Guitar Center.
Jun 23, 2009 at 7:17 AM Post #35 of 45
They don't completely eliminate the extra bloom, but does make it much more tolerable.
One problem with acoustic panels is that they are 4" thick. If you only have 6" behind the speakers now, after the panels are added you'll only have about 2" of breathing room behind the port. Will having only 2" of breathing room have more of a detrimental effect on the sound than the improvement you get from adding the panels? It will be a balance and a tradeoff.
Jun 23, 2009 at 7:36 AM Post #36 of 45
a5 is in another league... a2 are more comparable to the bx5a
from my experience buying active speakers, the bx5a has great highs, the mackie mr5 has great bass, but the krk rp5g2 sounded the smoothest/most neutral to me and that's what i ended up getting
haven't heard the a2 but i hear you cant go wrong w/ them
Jun 23, 2009 at 8:34 AM Post #37 of 45
I've got another A5 question, when I put my ear close up to either of the speakers, there is a lot of white noise/static, is this normal? It does this if I'm plugged into a source or not.
Jun 23, 2009 at 6:29 PM Post #38 of 45
I noticed the same thing shortly after I received mine. I don't know if I would call it "a lot" though. The noise level does not change with volume adjustments and I cannot hear it without having my ear right up to the speaker so I assumed it was an acceptable level of noise.
Jun 25, 2009 at 10:16 AM Post #40 of 45
Do you mean the built headphone jack on the front of your computer (or internal i/o drive)? Mine has one too but I get electrical interference noise.
Aug 1, 2009 at 2:09 AM Post #41 of 45
i got to try the BX8 which is 8" version of BX5. i feel that these have bloated muddy bass, which is definitely a big no no for me
Aug 1, 2009 at 5:56 AM Post #42 of 45
On a sidebar, I would recommend the Mackie MR5. They are great and i compared them to the BX5, JBLs and Rokit RP5. I found the Mackies to be the best and love every detail they produce. The JBLs were slightly better at detail but sounded very flat. The MR5s do not need a subwoofer, they have great bass. Also the Mackies have balanced XLR connects which adds a great amount of SQ to the output.
Aug 1, 2009 at 8:12 AM Post #43 of 45
I would agree there. But the amount of bloat does depend on placement. Properly placed with enough room behind the port and far enough from a wall the bloat is less. I also run my BX8a through an EQ that has an adjustable hi pass (low cut) filter. If I want to reduce the bloat I adjust the hi pass filter till it goes away. Sometimes I engage the EQ and the hi pass filter and sometimes I don't. Depends on how I'm feeling about the bass. I do think that M-Audio tried to make the speakers go just a little bit too low just to get better spec numbers (at this price point you're selling a lot of speakers just based on specs on paper as shoppers go spec comparison shopping). Using a hi pass filter fixes that to an extent. So would using a good sub and adjusting the crossover point so that the BX8a is not trying to go so low.
I still consider them $300 speakers (for a pair). So I'm not expecting too much from them.
Aug 1, 2009 at 10:23 AM Post #44 of 45
oh i thought i add on that i was able to listen to the bx8 at guitar center, however sadly they were placed at the lowest row of the studio monitor displays. nonetheless, when compared to a KRK VXT7 or 8 (i dont really remember the model name), the bass is most definitely bloated. i even crouched so i could get my ears as close to same level as the monitors.
Aug 1, 2009 at 11:21 AM Post #45 of 45
The KRK VXT8 jumps you up to the $1200+ price point per pair. That's quite a jump up from the BX8a. $1200+ can get you a very nice pair of monitors that outdo the BX8a in every way. The sound of the BX8a is fair for its price point. They certainly don't compete with higher priced monitors.
