Jasper994
Organizer for Can Jam '09
- Jun 3, 2003
It gives a too many channels error.
Originally posted by Iron_Dreamer Winamp ASIO: http://www3.cypress.ne.jp/otachan/out_asio(dll)_042.zip |
Originally posted by lan In the zip file there is a directory "bin" with different DLL compiles which use different CPU feature sets. I noticed he changed this where before he used to have different ZIPs for different compiles. Just move the DLL you need to your plugins folder. |
Originally Posted by Patrickhat2001 Jasper, Did you ever get this problem resolved? I bought an Audiohile 24/96 recently and I'm experiencing a similar problem. Actually I can't get the card to play music at all with ASIO unless I use 24 bit padded to 32 bit decoding but the card will play music with ASIO. it will play music as long as I don't touch anything--as long as I boot up Foobar and select a song to play and then just leave the programing playing without trying to select another song it will work just fine. But once I try to select a different song (or even stop the one I'm currently) playing Foobar will freeze up and will not do anything for about 20 seconds. After the 20 seconds have past it wil begin playing the new song. Talk about annoying. So the question is; has anyone been able to use ASIO successfully with an Audiophile card (or other cards of the M-Aduio Delta family)? |
