jonathan c
I have never been asked by PayPal for that data…I bet that the subsequent emails that you were getting were from ‘scammers’ posing as PayPal…
They've changed.Here's a few shots of one of my Treasure Globes when I first bought them.
I removed the top plate from my Lyr 3, before sending it back to the factory.Is the cover of the Lyr 3 able to be slid off back-to-front? The cover does not appear to be attached by screws.
Yes. It’s a pressure-fit thing. Studs on the lid fit slots in the chassis. She can be stubborn…Is the cover of the Lyr 3 able to be slid off back-to-front? The cover does not appear to be attached by screws.
Purchased mine back in 2018.They've changed.
Mine is graphite blacked, with a white base.
There are definitely scammers posing as PayPal. I called a 1-800 number that I googled for a PayPal number and the guy I talked to sounded legit but then he told me my account had been hacked and the questions he started asking me sounded suspicious. I told he was phony and hung up.I have never been asked by PayPal for that data…I bet that the subsequent emails that you were getting were from ‘scammers’ posing as PayPal…
• Quite the difference with the SR Purple in Lyr 3! Simply stated: lower noise floor, definitely greater dynamic range, micro details are more audible with texture, ‘clearer’ space between instruments & voices.
• My perceived sound source allocation has changed. Pre-SRP, 60% SS + 40% VT; post-SRP, 35% SS + 65% VT. Tube ‘rolling’ has a much greater impact with the SRP rather than the stock fuse installed. That, besides great sound, makes my day!
It is a bit of work. Read some of the posts before this one. I purchased the SR Purple fuses (and other items) from VH Audio which is located in North Prairie, Wisconsin. Check their website.Is it easy to take the cover off to change the fuse? Where would I get such a fuse?
How would you compare MZ3 and stock Lyr 3?It is a bit of work. Read some of the posts before this one. I purchased the SR Purple fuses (and other items) from VH Audio which is located in North Prairie, Wisconsin. Check their website.
For the Lyr 3, use the 5x20mm size, T(imed) 1A rating.These ones here? https://www.vhaudio.com/fuses.html
Which options for size, rating, and amperage value did you select?
