441879
- Dec 21, 2015
Something strange is happening. Sound came and goes, and I hear a tiny clik like a relè switching on and off. Could be a overheating protection? But its winter , how can I manage Summer? Do I have to put a fan on it?
Not normal at all and unlikely heat related. Have you tried a different tube? Unplug your HPs and all sources and preamp out and see if it does this with nothing connected except tubes.
Definitely not normal. As Ripper says, verify it’s not something else (tube, DAC, HP, etc). Once you’re sure it’s the amp, request a return number from Schiit and send it back for repair. It takes about 3-4 weeks with shipping which sucks, but Schiit will take care of you.
Will
Edit: This is kind of obvious but also make sure you don’t have the Lyr on top of a heat source or enclosed in something that could over heat it (like in an unventilated enclosure). The unit should be fine in a 90 degree F space, but it is possible to overheat it if there’s no free air movement around it.
