Buy from here for peace of mind.Do you know if there is a way to check the genuineness of the received WP1/WP2 cable? Thank you.
https://shop.musicteck.com/products/luxury-precision-wp2?_pos=9&_sid=190f033c1&_ss=r
My question was not about regretting a possible purchase or not...I am just seriously interested inDon't worry, just buy the W4, you will not regret it, that's how impressive it is, and don't forget to buy the original, blue leather case also.![]()
Comparing it to the Cayins it seems that the W4 charges the battery instead of discharging it… lolNice collection you have there. And your verdict is......?
You go into UAC menu and you press the knob and that's it. You will see the firmware version you have installed.Sorry but how do you check what firmware version you have on it? If I hold down the key as I did with the W1 it says 100... but what does it mean?
W4 is weaker then W1/W2 on the 3.5 mm.I noticed that to make the IER-Z1R sound it needs more volume clicks than the W1... the 400mw keeps them all for the last 30 clicks maybe...
What firmware version do you have installed?The IER-Z1R are connected in balanced, I don't even consider the SE... lol
