L&P will release a firmware update soon to fix the compatibility problem with the 8geb2 usb 3.2.
This post was last edited by Lebi Customer Service 1 at 2023-5-8 11:05
The compatibility problem is a two-way problem, that is, there is a problem with the UAC chip configuration, and there is also a problem with the mobile phone SOC chip. For example, if we do not change our UAC configuration, all mobile phones except some 8gen2 cannot be connected, which means that this SOC does have a compatibility problem. , we can actually change the code related to UAC connection to be compatible with 8gen2 mobile phones. We have actually debugged a suitable configuration internally to ensure the stable connection of Mi 13, but we have not dared to release it on a large scale because it may cause other problems. There are new compatibility issues with mobile phones, so the best solution is that the 8gen2 SoC can release a patch. In the past two days, we will strengthen the compatibility tests of various mobile phones and release a version of the firmware to update first.
We are not trying to shirk. As for the S23 mentioned earlier, it is compatible with USB3.2. We are guessing whether it may be due to the problem of the 8gen2 full-interface CC logic recognition mechanism. However, VIVO and MI13 U are full-interface and do not support it. It is possible to eliminate this problem. We are not afraid of slapping the face when we eliminate the problem. If there is a problem, we will solve the problem. "
