Luxury & Precision (LP) Portable USB DAC/AMP W1 and W2 (The new W2-131 Version is Available, Related Info on Post #1)
Mar 4, 2021 at 8:07 AM Post #451 of 5,299
Only MusicTeck as it seems
@HiFyAK2020 seems to have a direct wire to the production company....
Would be great if from Europe (since they have no dealers nor distributors) one could order directly from the company. It would be good for them also, since they would make a higher margin.
Mar 4, 2021 at 8:23 AM Post #452 of 5,299
Ummm... So a 200 euro dongle is only minutely different from a 7500 euro 6 DAC + TOL amp? Do tell. Now I'm definitely not buying the W1, as nothing can live up to that hype.
Well i am not a sales manager for W1and there is no hype whatsoever - so whatever you do is fine anyway - i just mentioned that this W1 has an incredible good sound quality and can match some very expensive Hifi gear - that's all really.
Mar 4, 2021 at 8:52 AM Post #456 of 5,299
Is the maximum power output the same on both 3 5 and 4.4?
Look at very first page of this thread
"Some data for its power level (the third party measured numbers rather than OEM-supplied numbers):
Balanced:
32Ω 235mw
Single-ended:
32Ω: 125mw"
Mar 4, 2021 at 9:04 AM Post #458 of 5,299
Cool,.so both W1and W2 have same power output? S1 can do only 70mw 32 ohm single ended and 125mw 32 ohm balanced.
These measurements are done with W2. W1 seems to have slightly less power. L&P’s own advertisement (can be found in Musicteck) says W1 can do 220mw at 32 ohm.
Mar 4, 2021 at 12:14 PM Post #461 of 5,299
Mar 4, 2021 at 12:53 PM Post #462 of 5,299
I ordered two of those now - thanks Babayagga - it looks like a great idea... only question is how to make sure the DAC does not move left and right behind the smartphone... with suckers its not possible since my smartphone case is think and rough... we'll see - how do you put it ? photos ?
There is little to no side to side movement on mine. Everything is nice and snug. One thing you could do is double sided tape or velcro if you really feel the need
Mar 4, 2021 at 1:12 PM Post #463 of 5,299
Im pretty sure Hifigo is Authorized also. I got an email from them about info of the W2 :)
Mar 4, 2021 at 1:24 PM Post #464 of 5,299
Mar 4, 2021 at 1:25 PM Post #465 of 5,299
Does the E1da give you any improvement over the V50 dac? The V series quaddac measures very good!
