MCC
- Oct 10, 2005
I've unfortunately ran into more problems with the vintage McIntosh receiver I rebuilt some time ago. I noticed earlier today that when I turned up the volume (for a low volume source), the cones on the speakers were traveling significantly farther than they ever should. They moved in a seemingly random pattern and it looked to be caused by a varying DC offset. I immediately switched off the power and checked inside- my multimeter confirms that the can caps are fine, and everything else looks fine visually. My output tubes are also biased within .005v of each other.
I substituted in some cheap Chinese tubes for the telefunkens, powered it up, and took this video with no inputs attached:
Oscilliscope reading video
What could cause issue, and where should I look?
Thanks.
Thanks.
