Lotoo PAW S1 - Designed for HIFI on the go with Lotoo PAW quality and the first USB DAC-AMP with dual 3.5mm & 4.4mm output
Nov 9, 2020 at 2:06 PM Post #1,340 of 2,329
I don't know guys. Won't pretend to know how hard it is to implement MQA, but I consider it a nice bonus if they add it in later. Don't hang your hopes on it.
Has there been precedent for other DACs/DAPs adding MQA after release?
Nov 9, 2020 at 3:20 PM Post #1,342 of 2,329
If I remember correctly, MQA support was added to the R6 Pro well after it was launched.
Nov 10, 2020 at 7:32 AM Post #1,345 of 2,329
Nov 10, 2020 at 8:05 AM Post #1,346 of 2,329
Hi guys - btw I've been considering using this in tandem with Onkyo HF Player for some high res action through my iPhone... I take it this would not share the iPhone dongle's 24/48 limitation?
N
Nov 10, 2020 at 8:46 AM Post #1,347 of 2,329
As I have read in ADSR forum on top of the licensing MQA is not that easy to implement, there would be an additional load for S1 to unfold MQA files
Nov 11, 2020 at 3:24 PM Post #1,350 of 2,329
Why this doesn't work on Windows 7. The description says it should. Anyone know the solution?
It works !! Read some more next time :
And also.make sure your are on 1.0.0.6 or above firmware :
Method of use: Hold the "+”key on S1 then connect to the playback device, "UAC1 MODE" will be shown on S1 during booting.
Reconnect without "+”key held will enter normal mode(UAC2).
Notice:In UAC1 Mode,Audio spec is fixed to 48KHz/16bit and no DoP supported
