Hubert481
Did someone compare S1 with rme adi-2 dac fs ?
with a Focal clear or similar....
Take a look at project perfection, they'ee based in singaporeWhere can you buy this aside from Amazon US? They don't ship the S1 to Australia and it doesn't seem to be on Ali.
https://www.head-fi.org/threads/lot...5mm-4-4mm-output.932676/page-74#post-15858322Can somebody suggest a lightning cable that doesn’t cost a fortune? Possibly in the US. Thanks
Thank you Alex, I’m looking for something more affordableMusicteck sells the official Lotoo S1 short lightning cable here.
Thanks but the usb c - lightning cable is not available for the US .
Dense Audio Adapt Reference has those liquid and smooth mids reminiscent of a pair of Audeze. Paw S1 is good but the midrange is a little too neutral and somewhat dryish. It's good if you are into the neutral sort of sound but the midrange on the Adapt is just beautiful.
Adapt also has tighter bass with better impact. I never liked the bass impact of AKM chips.
Paw S1 works great with BA300s mki and should work with mkii but imo Paw S1 is a little too neutral sound wise. It's a boring sound.Hi, I did not get it if you tried to put S1 together with the BA300s mkii, and if it's the case, has it been "worthy"?
I am speculating over this kind of combo, maybe a bit "stretchted" to some extent (the idea would be to put a smartphone at the beginning, and a pair of Isine 20 at the end).
Thnx
S1 with "headphone" mode make my Isine 20 Rumble and "emotional". Maybe I am far away for being "audiophile" After all, but I believe It Is a Little gem, from time to time being a tad congested.Paw S1 works great with BA300s mki and should work with mkii but imo Paw S1 is a little too neutral sound wise. It's a boring sound.
EFX (effects) and ATE (acoustic timbre embellisher) are fixed 'presets' in Lotoo DAPs while PEQ (parametric EQ) is obviously customizable. I think there is always a little bit of mystery behind these EFX/ATE and if it's a combination of dsp and eq. On S1 you don't have access to customizable EQ, but you can tap into all these presets. And whatever sounds good to your ears with earphones/headphones of your preference and the type of music you are listening to - that IS what's the best You know how it is, everybody have a different taste in sound and effects will shape and change the signature and tonality of your specific headphones, thus it all comes down to whatever you like!
