Lotoo PAW S1 - Designed for HIFI on the go with Lotoo PAW quality and the first USB DAC-AMP with dual 3.5mm & 4.4mm output
Jun 25, 2020 at 8:44 AM Post #453 of 2,329
Maybe not for you, but for many of us, no complaints what so ever.
I am happy for you if you are not experiencing interference after upgrading the firmware!
But to be sure that you aren’t, do one simple experiment... go into your source settings and disable WiFi to ensure you are only using cellular... Are you still not hearing interference? If no interference then your issue has been resolved! If you still hear interference then the problem remains as this is an issue only encountered on cellular to the best of my knowledge.
Jun 25, 2020 at 10:24 AM Post #454 of 2,329
it did not eliminate the static THOUGH i dont know how, they did mitigate it, i was coming home last night and in the elevator to my apartment is where i get the most EFI from, dont know if they implemented a filter, but it wasnt AS BAD as before, i was actually trying to listen to it. the first days i had this thing, efi there was unbearable. Romi's mod did help though, it helped reducing the noise a bit, but the FW did something, as well sound wise it feels different, sort of like the notes are heavier. more presence per se
Jun 25, 2020 at 12:21 PM Post #457 of 2,329
FYI, for those still struggling with noise, I have got my EMI noise down to unnoticeable levels with two very simple/cheap "mods":
- TitanRF Faraday Tape
- ddHiFi TC05 USB C to USB C cable
If you want me to test out any cases I can. My IEMs are quite sensitive (111db/mw) and I'm using balanced out.
Jun 25, 2020 at 12:59 PM Post #458 of 2,329
I'm intrigued by this little dongle, I have a E1DA 9038s ver 3 coming to check out but it's been stuck in China for 24 days - ali express shipping. So after reading some of these glowing impressions I ordered one. Checking out r3 pro saber which is very good.
Has anyone used a galaxy s10 with this dongle? I hope it powers it
Jun 25, 2020 at 1:25 PM Post #459 of 2,329
A friend was trying to figure this out too, so I sent him a screenshot of your suggestions. Thanks for posting this.
Jun 25, 2020 at 2:20 PM Post #460 of 2,329
The S1 use very little current and has great power output.
I am using mine with LG V50.
Rest your fears.
