US $209.00 5%OFF | W1 W2 decoding ear line DAC Apple Android phone hifi fever tpyec turn 4.4 3.5 small tail
https://a.aliexpress.com/_vSqthn
My Chinese language skill is badUS $209.00 5%OFF | W1 W2 decoding ear line DAC Apple Android phone hifi fever tpyec turn 4.4 3.5 small tail
Yes, but if you order W2 you get W2.My Chinese language skill is bad
In specs it seems to be W1 and not W2?
OK, now I found it, thx.Yes, but if you order W2 you get W2.
I have an LG v30 and almost all of my dongles have static when data traffic goes over the cellular connection, though never WiFi. I think most of these devices are susceptible, either due to poor internal shielding or the usb cable itself acting as an antenna picking up the LTE/4G signal. I may need to attach the S1 to my iPad and then put my phone next to the S1 with the phone’s WiFi turned off to see if the S1 picks up interference while I do data transfers on the phone... Up to now, I haven’t found a happy solution with a dongle if I am running cellular data...Quite a few people reported already, between comments I read here and a number of my readers pinging me in private, iPhone 12Pro/MAX is a culprit of the EMI problem. They switch to iPhone 8 or android phone, and problem goes away or EMI is a lot less noticeable. Of course, not an excuse since in theory you want usb dac/amp to be universal with every source. I assume when you try it with your laptop, you don't hear the same EMI level? or older iPhones or other Android phones?
Wow. Nearly 40% taxes and fees? That’s astonishing. How does it help to have a seller in Europe for the W2? Wouldn’t they need to pay the taxes anyway? You may save some on shipping, but wow, 118 Euro cost on a 300 Euro item...OK, now I found it, thx.
Guess I will first try S1 though as it is arriving tomorrow and consider W2 if s1 turns out to show issues with my setup.
Import fee is incredibly high for Germany.
W2: 300 Eur
Fast delivery:32
Sum: 332 Eur
Taxes: + 118 Eur!
Guess I will first wait for some resellers in Europe...
Of course it can happen that a Europe reseller will offer it for 400 Eur anywayWow. Nearly 40% taxes and fees? That’s astonishing. How does it help to have a seller in Europe for the W2? Wouldn’t they need to pay the taxes anyway? You may save some on shipping, but wow, 118 Euro cost on a 300 Euro item...
at least it is looking very nice!I just took a couple of pictures of my setup. I feel that the Fearless cable helps me a bit with interferences (or maybe I just convinced myself that a $135 cable was worth it )
I rather use the S1 with my laptop or LG G8S or Sony NW-A105, steaming from Tidal via WiFi because when I go out for a walk I prefer to use the Fiio BTR5.
The only thing that I don't like is the sound difference between laptop and smartphone/dap, from laptop the S1 sounds with more body and more energy.
Do you feel the same?
So ran a simple experiment this evening...I have an LG v30 and almost all of my dongles have static when data traffic goes over the cellular connection, though never WiFi. I think most of these devices are susceptible, either due to poor internal shielding or the usb cable itself acting as an antenna picking up the LTE/4G signal. I may need to attach the S1 to my iPad and then put my phone next to the S1 with the phone’s WiFi turned off to see if the S1 picks up interference while I do data transfers on the phone... Up to now, I haven’t found a happy solution with a dongle if I am running cellular data...
Guess you have yet checked the UApp settings and also bought the MQA in-App package?Just bought Lotoo PAW S1 as my backup since my iFi HIP DAC now is on RMA. This dongle is ridiculously good SQ and powered well for both of my 1more H1707 and new Hifiman HE400SE. But it baffles me when i'm using UAPP, as I'm playing in bit-perfect mode, Lotoo shows the resolution of 32bits even for all hi-res files I've played from UAPP. But when I'm using Sony Music Center Player App, the Lotoo will show the correct resolution same with the file.
This with UAPP
This one using Sony Music Center app
Check the setting, nothing out of ordinary. Using bit-perfect, yes this UAPP include with MQA while still showing 32 bits.Guess you have yet checked the UApp settings and also bought the MQA in-App package?
My S1 is delayed and will hopefully arrive on Friday
