zazex
Hmm, I'm having a hard time deciding between the Grado's, Shure's, and M50's.
I've seen those three recommended the most for a sort of entry level, price/performance headphones.
Looking at portable amps, they're a lot cheaper than I remembered them being.
IF I were to get a portable amp to accompany one of these headphones, does anyone have any recommendations? It needs to be the size of or smaller than an iPod Touch.
You wanted deep bass, per your original post. Scratch the Grados off. The Shures can do bass, but it's more of a neutral natural bass. The M50 can do good bass, but there's other options that have better mids, sound stages, treble, etc.
Suggestion: Fischer Audio FA-003 (or rebranded HM5), Shure SRH840, Beyer DT770 PRO. As for portable amp, Digizoid ZO2.
Very best,
Good catch, MalVeauX, regarding the bass. I hadn't gone back to the original post in a few days and
it had slipped my mind.
So we agree on the Shure 840. I've not heard the Fischer, but I know you like them very much.
(I've tried to get a listen, but their availability here in the NYC area seems spotty at best.)
I still recommend the ATH-M50, though it's apparent you're not its biggest fan.
I bought a pair when it they first came out, sold them, and bought them again.
I think they're very good for what they are, they're very fairly priced, and they will deliver the bottom end.
But - whatever.
And the Beyer DT770 is, I think, another excellent option for the OP especially with regard to bass response.
The FA-003's look a little large and seem like they'd grow cumbersome fast, although I won't dismiss it right away and I will look into it. And I'll look into the other two as well.
Also does the Digizoid ZO2 really improve the bass that much to justify a hundred dollar price tag? I'm not familiar with amps at all.
OP - The Digizoid ZO2 is a very recent release, though it's been awaited quite breathlessly.
It operates specifically on the bass, and also acts as an amplifier.
As for portable amplifiers,
you could also look at the Fiio E11 and the CMoy from JDS Labs.
The CMoy sounds better but the Fiio is smaller.
They both run about 50 to 60 dollars.
