Ticky
- Oct 24, 2003
Hi there,
Your user CP stated that you listen to all sorts of music. It might help if you could pinpoint out some genre that you generally listen to more frequently.
Generally, each brand usually have a particular sonic character for their speakers. Some are more mellow sounding, while others may be a bit more bright. So, let us know your listening preference. That might help with the suggestions.
Personally, I like speakers with a crisp sounding tweeter and a more relaxed overall sound. Thus, over the years I noted that I usually prefer the sounds of certain brands over others.
Good luck with the search!
