gbacic
- Aug 21, 2009
I don't find my HD650's to have basshead oriented bass; it doesn't slam my ears. I doubt it would fit your tastes.
I personally find the sonic signature of a properly amped HD650 to be very similar to the IE8s, and think you might be very happy with them. They're not bass monsters, but I think they're just right for a wide range of music types.
Yeah, it is weird. I think they're designed like some kind of ported subwoofer enclosure. Beyer's website says they have a 'bass reflex system'. Either that or black magic. I don't have my notes from canjam with me right now, but I'm pretty sure the 990s had more bass than the D5000s. I didn't give the D5000s and extended listen though, since I was concentrating in a bit lower price range, so I could be wrong. The 990s were something I was researching for a while before and I found plenty of people on here who came to the same conclusion I did. I think someone said the the bass went downhill from the open 990 to the semi open 880 to the closed 770, but It might have been 990>770>880. Also keep in that these are the 'premium' versions. For the 770 at least the are quite different from the 'pro' model. The 770 pros are supposed to be humongous bass cannons, but I have not heard them myself. I don't know if there are such large differences between the 'pro' and 'premium' 880s and 990s. I've heard that they have more headband pressure, but I don't know if that's the only difference.
But yeah, it's still strange.
The graphs aren't perfect, and its probably not even a graph of the right version (250 ohm and not a 600) but until everyone has a reference set of everything listed on headroom its the best we've got.
