My vote goes to the LCD-X. Get the creator package For $1,200 and use the other $800 to buy music. Not as expansive as the Sennheisers but won’t ever get shrill either. LCD-3 is more ear candy, but LCD-X is very neutral with real planar bass to boot.
I already own LCDXs. And they are fine headphones for sure. Non of headphones I have audition today had bass as impressive as LCDX.?And I did hoped that LCD-4 or 4z would give me a big step up in performance. Personally, I don’t think that’s the case. They’re better....... not significantly tho. Or should I say, not 3K better. Even at $2700 B-stock I am hesitant to pull the trigger. I think I’ll go with something “different” then slightly improved Audeze house sound.
Back to my store audition experience with ADX and HD800s.
ADX5000 surprised me quite a bit. For many reasoned but I’ll list just the most obvious characteristics that differentiate them from other headphones.
Ergonomics would be a good place to start my impressions with ADX5000. For me, these were one of the most if not the most comfortable headphones of the bunch. Maybe even more comfortable then my Aeon2C, which I couldn’t compare side by side. HD800s were just as comfortable by I felt that ADX5000 fit me slightly better. I can see myself listening to either one for hours without fatigue or discomfort.
Build- ....... that’s a though one. Both headphones feel a little “plasticky” in comparison to other headphones. Not sure how that corresponds to long term use but I’m pretty sure my LCDX will outlast both of them and than some. HD800s seems like a better, complexed build in comparison as ADX5000 are basically raw drivers, pads and headband. Not a whole lot of material went into this particular design. But it works and it does so without apology. I would give them both about the same score when it comes to build and comfort.
Performance of ADX5000.
This is going to make me look very foolish........ or maybe, it is just my taste and biases towards specific kind of presentation. Here it is.
ADX5000 seemed to me as the most balance performer of them all. And it seems like they won’t need help from EQ to “fix” some anomalies found in other designs.
Top is extended, airy, detailed, effortless. Vocals sounded right without bringing to much attention to itself. Not saying it was perfect but on par with the best of the bunch. Bass was satisfying, articulated and certainly better then HD800s. Soundstage was very nice, pretty wide but fell short in comparison to HD800s. But I think it’s better then my LCDX and much wider then Aeon2C. That’s for sure.
HD800s might be slightly more analytical, precise, pinpoint like accuracy. If I had to chose headphones strictly for gear evaluation, HD800s would be a great tool to use. String instrument on HDX5000 sounds quite fantastic. Plenty of body, decay, pitch, reverb. Strings just sound as natural as it can be at this price point. I don’t think my LCDXs can do strings like ADX5000 can..... I would have to have these two side by side to be sure.
Another thing about them, they’re not boring. Sound is lively, open, detailed and place you pretty close to the performer. Which I like.
HD800s have similar presentation but it’s somewhat disconnected. I think it’s because of very present treble and midrange/bass that seems to play catch up game. It’s hard to describe.
Some say that ADX5000 is a direct competitor to HD800(s) and they might be right. They’re more similar then different in their presentation and technicality. And if you look for that kind of presentation and sound, you should definitely listen to them both side by side.
Both sound fantastic with my tube amp. And I think you’re doing yourself disservice if you run either of these with SS amp.
ADX5000 sounded OK on SS. It wasn’t bad or anything like that but that airy treble and what seems like elevated energy (IDK 8-11K region) at certain treble frequencies were just a bit too aggressive for my taste. Same thing but even worst with HD800s.
With tube amp in the mix, both headphones turned 180 degrees, especially HD800s. Peaky treble was gone. Soundstage seemed to slightly wider/deeper. Strings and vocals gain a bit of extra body and “romance”. Tube amp is highly, highly recommended for these two headphones. And for HD800s, it’s a
must.
So which one did I prefer of the two?
As controversial or shocking as it may seem, I would have to say ADX5000.
More later and reveal of headphone “X” that was thrown into the mix and kinda ruined my day.
