Looking for EQ APO settings for Beyerdynamic DT990 premium 32ohm
Mar 31, 2018 at 2:26 PM Thread Starter Post #1 of 5
JewFerrigno
canada
Just bought some dt990 premium 32ohms got them for a steal! Currently I'm using some EQ APO settings for I think the 250 or 600ohm version. Sounds great but I just want to see if there are any settings more specific to the 32ohms that might work even better for me
Headphones plugged directly into audigy fx 5.1
I'll Paste the current settings I am using
Any suggestions for me to try out would be much appreciated!!
Current settings:
Channel: ALL
Preamp: -2.8 dB
Filter: ON PK Fc 20 Hz Gain 3 dB Q 0.9
Filter: ON PK Fc 145 Hz Gain -3 dB Q 0.6
Filter: ON PK Fc 360 Hz Gain 1.2 dB Q 4
Filter: ON PK Fc 650 Hz Gain 2.5 dB Q 1.3
Filter: ON PK Fc 2300 Hz Gain 1 dB Q 4
Filter: ON PK Fc 3000 Hz Gain -1 dB Q 4
Filter: ON PK Fc 4390 Hz Gain 1 dB Q 7
Filter: ON PK Fc 5840 Hz Gain -8.2 dB Q 4
Filter: ON PK Fc 7300 Hz Gain 2.5 dB Q 7
Filter: ON PK Fc 8220 Hz Gain -11 dB Q 5
Apr 5, 2018 at 5:26 PM Post #3 of 5
I'm guessing you could improve the audio quality of the DT990 32-Ohm headphones by replacing the Audigy FX 5.1.
Maybe find a good deal on a used Sound Blaster Z sound card (better DAC & head amp).
Aug 30, 2018 at 12:54 AM Post #5 of 5
these are the EQ APO settings i got from using the tutorial:
Preamp: -6.1 dB
Filter 1: ON PK Fc 10494 Hz Gain -13.2 dB Q 1.00
Filter 2: ON PK Fc 269 Hz Gain -4.8 dB Q 1.00
Filter 3: ON PK Fc 9734 Hz Gain 10.8 dB Q 2.30
Filter 4: ON PK Fc 6305 Hz Gain -6.5 dB Q 2.08
Filter 5: ON PK Fc 1171 Hz Gain -3.9 dB Q 1.00
Filter 6: ON PK Fc 91.3 Hz Gain -4.9 dB Q 2.00
Filter 7: ON PK Fc 64.3 Hz Gain -4.5 dB Q 2.00
Filter 8: ON PK Fc 129 Hz Gain -4.4 dB Q 2.00
Filter 9: ON PK Fc 1703 Hz Gain 1.7 dB Q 1.00
Filter 10: ON PK Fc 44.7 Hz Gain -3.8 dB Q 2.00
Filter 11: ON PK Fc 180 Hz Gain -3.0 dB Q 2.00
Filter 12: ON PK Fc 31.7 Hz Gain -2.4 dB Q 2.00
Filter 13: ON PK Fc 4750 Hz Gain 5.4 dB Q 5.00
Filter 14: ON PK Fc 13842 Hz Gain 4.0 dB Q 2.94
Filter 15: ON PK Fc 3903 Hz Gain -3.3 dB Q 5.00
Filter 16: ON PK Fc 3102 Hz Gain 2.1 dB Q 5.00
Filter 17: ON PK Fc 695 Hz Gain 1.1 dB Q 3.14
Filter 18: ON PK Fc 2562 Hz Gain -1.2 dB Q 5.00
Filter 19: ON PK Fc 5613 Hz Gain -1.5 dB Q 5.00
Filter: ON LSC 12 dB Fc 100 Hz Gain 6 dB
