The card has just arrived, it's actually model SB0460
Some close ups of the card and the S/PDIF section.
There are two sources for S/PDIF on this card, the multi-jack and an S/PDIF header.
The S/PDIF header uses pin 9 for S/PDIF output.
The multi-jack on the output has it's outputs (both tip and ring) tracing the input/output pins of the 74HCT4053D multiplexer (
http://www.nxp.com/acrobat_download/..._HCT4053_4.pdf), pins 2 & 5.
There is a 74F125D buffer (
http://www.fairchildsemi.com/ds/74/74F125.pdf) that feeds both the S/PDIF header and the multiplexer, but off different pins.
Pin 6 is used to drive the S/PDIF header and pin 11 is used to drive the multiplexer.
There is 33R inline with both S/PDIF signals.
Time to throw in a pulse transformer and wire up a BNC jack instead of the AD_Link breakout.
Since the S/PDIF signal is taken from different sources and I cannot trace it back any further, I'll first try to connect the transformer to the S/PDIF header, and if it doesn't work (as in doesn't pass EAX and CMSS-3D), I'll use the outputs from the multiplexer and if needed, short out the multi-jack.
Of course I can't take credit for all of the modding, a great thanks to
cetoole for helping me through email in picking transformer and recommending how the mod should be done. I just trace the card and try to sound smart.
