Originally Posted by Ross1 /img/forum/go_quote.gif
I have a EMU 0404 USB, and I would just like people to be wary that the drivers still seem to be fairly poor for it. For instance while it worked fine before, when I installed a new copy of windows XP..... it ****s up good and proper. I have tried everything to get it to work........
I have noticed some goofy behavior when interfacing the 0404 USB with either my notebook or desktop.
1. With the notebook....Compaq V6120, running XP Media Center SP2....if the 0404 is connected to a USB port
and powered up before my boot-up/start-up is completely finished, I get the default appearance XP taskbar (the blue one, with green Start button) rather than the "Windows Classic" gray, the one selected in my default theme. Apps appear in Windows Classic-style windows--the only problem is the taskbar appearance! The problem does not occur if the 0404 power switch is left in the off position until my desired taskbar appears.
2. With the desktop.....Compaq SR1575NX (maybe, I'm away from home and don't recall the exact model, running just XPSP2) random characters in the Start menu and in names under the icons on my desktop are underlined, as are some in the search window in IE7. It doesn't happen 100% of the time, just a majority of the time. Again, if the 0404 is not powered up until the start-up is complete, I don't seem to have the problem.
I'm still trying to figure out why on my notebook, running Foobar 0.8.3, I can change the PPHS resampler rate on-the-fly and the 0404 resyncs immediately maybe 90% of the time; pitch and playback rate change the other 10% of the time. With the desktop and 0.8.3, I'd say that it's the other way around--it only resyncs properly about 10% of the time.
Yes, it does seem that the 0404 drivers are not bulletproof and apparently "don't mind their manners" when impacting XP settings.
On the other hand, my son had a Transit working very well on his Dell notebook, and after he fixed some other problems, the Transit now refuses to work the way it did previously. I think he told me that even though Foobar shows that the output is set for kernel streaming, the XP volume control still works....so apparently it isn't really kernel streaming after all, now. Prior to the changes, the volume control was bypassed.
Neither of us is an XP configuration expert (though he knows much more than I do!) but still.......almost any other peripheral device that I have used since the introduction of XP has worked almost flawlessly from the get-go, but audio devices seem to have minds of their own.
