CCHD-950X
This is a starting point for experimentation and not a recommendation, it worked well with the 9018, the 9038 might behave completely differently so that is the downside.
LKS made a really strange choice using the large electrolytic for the XO regulator.
They look like Nichicon MUSE audio caps, this compromises the performance of the TPS7A47 regulator.
The MUSE caps perform very very poorly at the 100MHz range, most of the work is done by the small ceramic cap, the brown one on the side.
I normally expect to see low ESR solid polymer caps here.
LKS may have done this to dull out the sharp and harsh presentation of the 575-50.
I have marked the caps with the red "X" below, they probably need to be removed and replaced with regular solid polymer caps if the XO is swapped as the 950X does not require such drastic measures to bring it back into line.
