Tomus4
- Sep 19, 2016
Leave the LT1763 alone, the low noise specs are only guaranteed if the layout , especially the ground plane is done to the manufacturer's specs, there is not enough space on the board to put in another chip without compromising this requirement.
Layout, not datasheet specs determines final performance, please keep this in mind when reading the datasheets.
A hacked in regulator is about the worst thing you can do to the DAC, it compromises the noise performance. In the example below the 3/4 inch piece of the lead on the transistor is enough to act as a radio antenna, this injects noise into the regulator. In an area with good FM/AM radio reception this is 300uV or more (This is how simple germanium diode AM radio receivers can function).
More importantly it adds unwanted distance between the regulator and the load, this degrades the load transient recovery performance of the regulator.
Transient recovery is the ability of the regulator to quickly recover to the set voltage in the presence of a sudden increase or decrease in load current, which happens when digital logic changes state.
What do you thing about creating supply for clock and D/A converters based on this http://www.ti.com/lit/ds/symlink/tps7a87.pdf? I'm thinking about removing all LT1763 and stuff around and creating small supply boards which will be connected just before clock and converters.
