Ok, and the two above I just live it with the original opamps right? I thought that the opamps that needed to be changed for the XLR ouput was the ones above.
One more question. Why is there a difference if we put in a seperate power transformer for the USB power supply? The power tranformer for that is already in the dac has two outputs where one is not used. Could you please explain the difference.
This is what I got from Sonic Imagery Labs:
The Model 992FC-Enh-Ticha single is a higher output current drive option
(150mA vs 175/200pk mA) and the 3 resistors in the audio path are
replaced with (1) TaN type in the internal comp and (2) Vishay Naked
Foil type in the drive stage. This option is special order and adds
$40.00 to the cost of the opamp. ($89.00 total/ qty 1-4 pcs)
The 994 is the DUAL opamp equivalent of the Model 992
The Model 994FC-Enh-Ticha DUAL is a higher output current drive option
and same components above replaced. This option is special order and
adds $80.00 to the cost of the opamp. ($174.00 total/ qty 1-4 pcs)
I also got a response from Antec. I just need to serial connect the AC input to get the 230v. Only one channel will be used to power the USB board. Could I use the other channel to make a 12v trigger out port? But that is only 7v so maybe I can use the standard power transformer to make the 12v trigger out. Will that be wrong? Or will that interfere with the sound quality?
Thanks
The ES9018 has balanced output, the XLR balanced drive comes straight out of the current-voltage (I/V) convertor (the Tichas)
The decision of changing the opamp for the unbalanced side is up to you, it is not needed for XLR operation.
The USB interface on the LKS has a galvanic noise isolator, the enhanced USB board must be powered separately, if you reuse the the existing transformers, the noise from the computer will have a way to get into the DAC.
994FC-Enh-Ticha DUAL is the best option, this has the widest range of Class-A operation of about 26-28mA, the ES9018's maximum current output is 32mA, the I/V convertor operates in Class-A mode about 88% of the time. (The numbers for max load current the manufacturer quotes is for Class AB mode, this mode is not good if you are after a good sounding DAC)
You have to use both secondary 7V windings for the USB board, a single winding may not supply enough power to keep the board stable, the board might continue to work but the performance of the Crystek Femtoclocks will be affected.
Use a power sensing strip with an adjustable trigger and plug in a 12V wallwart or transformer for the 12V trigger.
http://www.amazon.com/Smart-Strip-SCG4-Autoswitching-Technology/dp/B000L9A7ZS/ref=sr_1_9?s=electronics&ie=UTF8&qid=1458296327&sr=1-9&keywords=smart+power+strip
