mordy
- Aug 8, 2010
In my Little Dot days, using external power supplies and voltage regulators, I used to measure the voltage at the tube pins. For power tubes there was always a drop, but not much. With 2.5A tubes the voltage regulator had to be set to 6.7V to get 6.3V at the tube pins with certain tubes.Our Italian member @lupoal discussed the importance of correct heater voltage previously. I found this quote on this site tonight: .http://www.emissionlabs.com/datasheets/EML300B-25V.html
"Heater Voltage: Some people experiment with lower filament voltage, to expect better lifetime. This is essentially wrong to do. If the magic was that easy, we would make the tubes like this ourselves. Under Heating can lead to early loss of emission, though new EML tubes will fully recover once the heater voltage is corrected, older tubes will recover only partially. The specified filament voltage at 0% tolerance is the one for best lifetime. The voltage we specify, is at the TUBE PINS itself. Any voltage drop by the socket contacts must be compensated for. For 2A3 tubes, some sockets have 50mV voltage drop per pin, because the heater current of 2.5 Ampere is very high. Causing a total drop of 0.1V for both pins together. So a voltage of 2.6Volts at the socket pins is needed, to make sure there is 2.5 Volts at the tube pins".
I have nothing to add to this due to lack of knowledge and experience. I don't know the magnitude of loss of lifetime, if so.
Usually data sheets for a tube will show the specified voltage +- a percentage range.
https://frank.pocnet.net/sheets/049/6/6080.pdf
If you look at this data sheet for an RCA 6080 you will find the factory voltage specification 6.3V +-10%. That means that this tube will function according to factory specifications between 5.67V - 6.93V.
Perhaps certain tubes must be run at a very specific voltage without any variations, but IMHO all the tubes we normally use have a range where they perform according to factory specifications.
It seems to me to be unnecessary to fuss over minor voltage variations. Many people report using the same tubes for years without problems, and slight variations in the voltage are not going to affect tube life.
