ok, it's time to put hands inside the LD...
following the original project and some suggestions from people here inside but also from other italian formuns and one of my friends (he is a appreciated hi-fi manufacturer) I left the two output tubes floating, that means no connection between the 0Vdc supplying them and the 0Vdc inside the LD electronic, and I grounded the two inputs tube connection the 0Vdc supply not were is in the original project (that is elevated of few volts) but at the 0Vdc of the electronic... the first picture is about this connection, the others are about cutted and identified cables from original transformer and DIY cable gland output (the holes inside the LD2 backplate are only 10mm diameters.. I've not been able to find any industrial PG with out 10mm and inside 4,5mm) so I had to realize one by myself
about the cables, those are 4x0,34mmq which more then enough to drive the tubes... I named "high" that one dedicated to the two output tubes... as both are M12 male + M12 female just cut them in two parts and you will have a perfect prewired cables that will allow you to disconnect PSU from LD if/when necessary and reconect with reliability
then comes the time to connect them togheter, without any powering on the LD and without tubes, just for check there are no shorts or missing connections and to measure the voltages at the valves sockets
ok... no smoke... good ... the voltage with no load at sockets is 0,1Vdc below the value on the display
