mordy
- Aug 8, 2010
Hi cape town watches,Thanks. I respect your opinion and appreciate your feedback and experience.
We are not talking money here, the tubes are cheap.
Therefore I will grab a pair of matched/balanced and two random pairs and simply compare them.
I am certain I won't hear any difference at all and I'll have enough tubes for the rest of my life!
As a newcomer to Little Dot products in particular and tubes in general, please can I ask you to explain what you meant by "Since the Little Dot has no power tubes and they are not in pairs, there is no benefit for using matched tubes."?
It's bugging me...!
Don’t bother with matched tubes.
In addition, a quick eBay check shows 6N6P
Thank you all for your advice, all your opinions are somehow similar, that a real upgrade to Little Dot would be an Elise or Euforia (this one I do not really think I will afford in the near future). The MK3 or even MK4 are no match for it and the idea to keep the current "tube" collection is not feasible, since even this might be a drawback of the Little Dot family.
I know the title and focus of this thread, and I do not want to continue discussing other models here, where our purpose is to talk about LD tube rolling, but I will ask only 2 last questions about Elise, since I found someone who owned both LD and FA models.
1) How are the Elise stock tubes? They are decent and usable? Because the MK2 stock ones were pure garbage according to my taste and expectations.
2) I already own 2 C3G (Siemens) and 2 6SN7WGTA Jan Philips '86. Can I use these ones on Elise (of course changing current adapters)? (I guess both as drivers according to the manual, so for power tubes I will have to buy some 6N13S or keep stock ones).
I own also some 6H8C from 70s but they did not sound as expected on LD, I have not idea if these ones are usable on Elise or other amps and sound better.
Hi OH,Thank you all for your advice, all your opinions are somehow similar, that a real upgrade to Little Dot would be an Elise or Euforia (this one I do not really think I will afford in the near future). The MK3 or even MK4 are no match for it and the idea to keep the current "tube" collection is not feasible, since even this might be a drawback of the Little Dot family.
It is very important to know that since most vacuum tubes are not being made any more, a manufacturer is limited to a reliable supply of either current production tubes, or out of production tubes that still exist in large quantities. These factors dictate the choice of tubes offered,
The factory supplied driver tubes for the Elise have changed over time, but the power tubes have remained the same. The tubes supplied are a good combination to start with.
There are better options, but such tubes often are harder to come by and only available in small numbers.
I think originally the Elise came with Foton tubes, then Russian Reissue Tung Sol 6SN7GTB, and now Psvane tubes (with some upgrade choices). The power tubes have remained Svetlana 6N13C.
The C3g (with adapters), the 6H8C and 6SN7 will work fine in the Elise, and the Fotons will sound better than in the LD.
By reading this thread you will get a good idea of what to choose. In addition, synergy between different combinations of driver/power tubes is very important.
Happy tube rolling!
