On a slightly different tack, but after all we are all trying to squeeze the last ounce of performance by tube rolling are we not? And sometimes paying quite dearly for it, lol!
Something I had been mulling over for quite a while - brought to a head by a VERY annoying tendency for a channel to disappear when waggling the headphone cable! - and that was to see if I could get similar improvements to when I replaced the internal wiring of my Dynaudio speakers, and did away with the binding posts, soldering direct to the board. What a massive difference that made - using pure silver wire, mind you...Anyway, as I had to undo the Neutrik socket to see what was going on, my mind was made up there and then - so-called "upgraded socket" on the MKIV SE? - If this is the best Neutrik can do, I would advise EVERYONE to get rid ASAP!! Actually, when you think about it, it is rather silly to go spending a lot of money on upgrading cables/plugs/mains filters etc. etc. for the lovely new signal to get trashed by the headphone jack/socket combo.
So it is I duly removed said culprits (actually, the cable fitted nice and snugly through the hole in the socket) and soldered the silver darling direct to the board...gone is the aforementioned occasional loss of channel, and even before the new solder has settled in I am seeing positive results viz - the Tesla E88CCs (with gold pins and grids) that have just recently gone in, and which were sounding rather lacking in the bass department compared to the Telefunkens (mind you, it is early days of course...) are all of a sudden almost matching the TFKs!! So this is boding VERY well indeed - can't wait to get the latter back in and see what transpires...my lips are smacking already...
The upshot is, of course, if you have just basic soldering skills you might want to give this tweak a try...the front panel on the MKIV SE comes off easily enough (don't know about other models) and there's plenty of room to work on the solder points. (The volume knob does have a VERY tiny allen inside, but in the end mine was dud and the knob was actually being held on the spindle by a piece of insulating tape!!...Mmmm...)
I am a firm believer in having as few 'connectors' in the signal path as is possible - as you may have gathered...
Cheers!
Cheers!
