gibosi
- Oct 18, 2012
I have a general question, what is the most detailed and dynamic tubes out there for the Little Dot 1+?
Tubes that blow the ones mentioned in the original guide out of the water.
I would like mod-less, to easy to mod tubes if possible.
Any ideas?
I will suggest a couple, and I am sure others have more to add.
6AV6 (and 6AT6 and 6AQ6) These are easy to mod, just cut off pins 5 and 6 and use the EF92 setting. The best tubes are those with a box-like structure (a box getter) on top of the mica:
http://www.head-fi.org/t/563884/little-dot-tube-amps-vacuum-tube-rolling-guide/3285#post_9859647
6HM5 / 6HA5 / EC90
No mods required. Use the EF95 setting. You want to avoid the short squat tubes that look like the typical 6AK5,
http://www.head-fi.org/t/563884/little-dot-tube-amps-vacuum-tube-rolling-guide/3300#post_9862250
http://www.head-fi.org/t/563884/little-dot-tube-amps-vacuum-tube-rolling-guide/3045#post_9828452
