mab1376
Dunno if anyone else had this issue, but I broke 2 6AV6 tubes so far cutting pins. The base cracked one one of my RCA and one of my Sylvania.
I have cut probably 15 pairs so far and never had this happen.... Perhaps your cutters are a bit dull?
They're brand new blue point lead snippers. They're ridiculously sharp. I had no issue on gold pins.
Luckily it only happened to one of my 3 RCA tubes, but I only had 2 sylvanias so i no longer own a pair.
I also covered the pin with a cloth so it wouldn't go flying away, maybe that caused it to resonate the impact into the glass?
@MIKELAP What dremel speed did you run the rubber tip at to clean up the pins? I can see that going wrong quickly with bent pins everywhere...
I shall have to try this method as well, even though the carbide does work satisfactory.
Thanks MIKELAP!
Is that a Dremel brand bit or a Princess Auto / Canadian Tire version? I might just have to stop in at PA on the way home...
Got that set at Canadian Tire a few years ago the set was on special at 1/2 price ($15.00 or so )so i bought 3 sets like this always useful .
