Originally Posted by Andrea
db597, btw, would you mind quickly telling what you gain in sound quality with the Headfive over the Micro+ ? Just to cry a little over what I've missed
Andrea, I initially wrote a long reply about this. But the Head-fi server was acting up for a few hours. I couldn't post. In the end, I closed my browser my mistake at it was all gone.
Let me sum up the main differences quickly:
1. there is far less background hiss with the H5. It's noise floor is much lower.
2. the H5's treble is less sharp. The detail is there, slightly more than the LDM+, but it's just not so shrill. Great, in my opinion, for taming Grados. Not so sure about the HD650, since that is rather warm already.
3. bass is more natural. I found some colourations in the bass with the LDM+ when paired with my ER6i. The H5 doesn't show this.
4. you can use the cross feed to get an even wider soundstage. The downside is that the spatial positioning of the instruments becomes a bit less precise.
Ultimately, the 2 amps are very different in terms of price and usage (portable vs. fixed). So I would expect more from the H5, and it does rightly deliver more. These observations were between a 150 hrs burned in LDM+ and a 10 hour burned in H5. I've not done another side by side since then. The LDM+ is now attached to a PC in another room from the H5. If anything, the H5's treble has opened up a little more since then.
