Jbucla2005
- Sep 16, 2005
That amp is very sensitive to all kinds of interference. I had a clicking noise issue when the amp was too close to my DSL router. Also some tubes I've tried have been noisy. Strangely, a quick fix for this noise was sometimes wiggling the tube gently in the socket and trying to secure it. Usually it would come back though... I never had a lot of problems with the GE 1U5's though, and when using the amp in another room away from my router. With other amps, I have had issues with 'ground loop' when hooked up to certain wall sockets. It could be this too...
Originally Posted by Svperstar Early Impressions, only 20 minutes of use or so. This smooths out the SA5000s quite a bit. It isn't an extreme night and day difference, but it is very noticable. I like it It gets damn hot, very quick, I am not sure I woudl be comfortable falling asleep with this guy running. When in pre-amp mode with the Gilmore Lite the bass has a wierd little pang to it I haven't ever heard before on any headphone or amp, the soundstage also shrinks on the Gilmore Lite. Also compared to the GL the volume knob on the LD feels cheap, not as cheap as the X-Fi Elite Pro's knobs but not as nice. Than again it costs only 50% as much as the GL. Oh yeah, despite everyone and their mother assuring me it does not this amp does have a slight buzzing as was reported earlier. This disappoints me a lot. What do I mean by buzzing? Hook up your headphones, and turn all music/sounds off, then just turn the volume to the max. It is more noticable in the left channel but is also in the right channel a bit. I don't know if this amp has crossfeed, or if maybe my left tube has a problem, either it I am very annoyed that this amp adds noise to the signal. On the Senn 580s you have to turn it up to about 85% of maximum volume to hear it, however on the hyperdetailed and brutally revealing SA5000s, you can faintly hear it at 55-60% of volume. Music does drown it out but that isn't the point, it is the principle of the thing, the amp shouldn't add noise to the signal. For example the Gilmore Lite adds absolutely nothing to the signal, turn it to full blast when nothing is playing and that is what you hear, absolutely nothing. I am going to try swapping the tubes and also switching the wall socket to see if that makes a difference. Post more later |
