pinnahertz
- Mar 11, 2016
...or, this example that shows how crossfeed can collapse the otherwise enveloping and dimensional image.
Well, I don't know of a speaker setup that is spatial distortion free, to use your terminology. None are. And that's hardly simple, is it?
Not at all. In fact, you're NOT using the Linkwitz definition!It seems our definitions of spatial distortion varies. Mine comes from mr. Linkwitz and according to it speakers can't produce spatial distortion because of acoustic crossfeed which happens always no matter what the setup is. In other words spatial distortion has to do with excessive channel separation (at low frequencies were our spatial hearing uses ITD and assumes mild ILD) and since crossfeeding in effectively reducing channel separation, crossfeed reduces / removes spatial distortion according to this definition.
I suppose your definition is about how accurately the sound image (angles and distances of instruments etc.) resembles the original? If so, a lot of our debating could have been caused by differing definitions of concept "spatial distortion".
How on earth would you know if it's distorted or not without knowing what the original was?That's is a very good and headphone-friendly recording with almost no spatial distortion. I would listen to this crossfeed off or with very weak crossfeed, because the spatial information is so on point.
No, it belongs to a HUGE group of recordings that have many things in common, including that sort of spatial presentation. 2% is your own made-up figure. The vast majority of classical music is recorded similarly. And yet you'd still use crossfeed!To give final judgement of this recording I'd like to hear it with CD quality, but it may belong to the 2 % of recordings without spatial distortion (excessive channel separtion).
You have now contradicted yourself.That's why cross-feeders must have off switch. Yes, even I listen to recordings like this one without cross-feed because you don't fix what isn't broken.
I've bolded and italicized the portion of your sentence that actually reflects the truth. You hate the sensation of excessive channel separation. You are possibly unique that way. However, that sensation doesn't even begin to fully define spatial distortion (according to Linkwitz), with the foremost being a too-close perspective, or inside-the-head localization, neither of which your cross-feed addresses...at all.Unfortunately most recordings don't have this kind of spatial properties and I want to use cross-feed because I hate the sensation excessive channel separation makes me suffer.
Great! That's your opinion. But you are NOT correcting spatial distortion! You're re-mixing the recording according to your preference. That's it, that's all, nothing more.To me cross-feed makes bass more "real", sound image smoother, vibrating helmet go away, band midgets jump from my shoulders to a few feet away from me to and grow in size, impulse-like sounds become steady points in the sound image (triangle, drum etc. is hit in a certain sharp point) and fatique problem goes away. It's more like just listening to the environmental sounds in that sense.
Yes, and let's just keep it that way.So, that's how I see (hear) cross-feed. Your mileage may vary… …maybe I should feel lucky since cross-feed does so much good for my headphone listening?
the big issue is that for headphones, be it the signature or a crossfeed setting, the answer for you might not be the answer for me. part of the signature you perceive as flat comes from signature change created by your own body. when you use a headphone you bypass those changes so ideally the headphone should have them in it's signature to compensate and still deliver a balanced signature for you. the issue their is obvious, I don't have your body. so I'll need a more or less significant change in signature compared to you.I've been a little curious about crossfeed myself, but don't really know enough about it to know if it will help any .
I really don't have a clue on what to do about fatigue. All I know is that it happens , and I lose focus with the music and have to walk away for a few hours. I don't listen extremely loud either. It varies between 60to 75db (with peaks).
What does it for me is trying to keep the sound as a whole. Then the separation starts to work on me.
I'm open to any suggestions that would help. Speakers are a no go in my situation lol.
Great! That's your opinion. But you are NOT correcting spatial distortion! You're re-mixing the recording according to your preference. That's it, that's all, nothing more..
that works.If your fatigued have a nap, solved
for crossfeed it's the same issue, the amount of attenuation at given frequencies should ideally align with how the sound would be blocked by part of your face, or how it would bounce from your torso... as for the delay for sending the left channel into the right ear, that should ideally be adjusted to your own head and the delay sound in the air take to travel from one ear to the other from a 30° angle sound source(if we decide to mimic speaker position).
which is why there is no great universal signature and great universal crossfeed acclaimed by everybody. we need to set those stuff ourselves and it takes time, patience and ideally a good speaker reference to easily compare what you have on headphone and adjust it.
also why as you can see, there is no consensus on crossfeed, that's because basic crossfeed is and oversimplification of speaker sound on us. so how much benefit you receive is kind of subjective and also a function of the music you're listening to. music mixed and mastered on speaker for speakers aren't providing the proper stereo signal for headphones. that is a fact. crossfeed is IMO a halfway measure(the big idea is right, the application is oversimplified), and as such the value really lies in how bad the music's "imaging" is for you on your headphones. so we're back to custom needs and custom appreciation.
another very subjective opinion: I would run away from long listening sessions with a non EQed HD700(or 800 for that matter).
That is exactly what happens. Differences in the room acoustics, LP, speaker position, and speakers themselves.If that was the case then people would be re-mixing their recordings acoustically every time they listen to loudspeakers.
In Your Opinion. But you did say "your mileage may vary" too. So which is it?Because I know how bass sounds. I know what smooth means. I know that music is for pleasure, not suffering. Crossfeed make the sound more speaker-like and that's what the music was mixed for in the first place so I know I am going to the right direction even if I don't get the same level of sonic depth than with speakers. That is so difficult that my skills are nowhere near to tackle it, but I can do a lot.
And your collection represents that of every other headphone listener in the world? Your statistics are YOURS, not anyone else's. You state your stats like they are global, which gives the wrong impression to readers in general. I didn't cherry-pick the example, it's an easy search in YouTube.2 % of my 1500 CDs is 30 CDs and that's pretty close to how it is. It is a rare occasion when I say "Wow, this CD doesn't have spatial distortion." If most of your CDs are like that example then you probably have a lucky taste in music.
Here: In post #48 you said, " I would listen to this crossfeed off or with very weak crossfeed, because the spatial information is so on point."Really? I said 98 % is broken, 2 % is not and I don't fix that 2 % because it's not broken. Where do you see contradictions?
You are unique in your propensity for presenting opinion as fact in a public forum. People around you? Who? And what recording where they listening to at the time?I don't think I am unique. People cross-fed long before me, even you did! People around me tend to admit that cross-feed is beneficial.
...or you made it up on your own?I thought I got the definition of spatial distortion from Linkwitz since his cross-feeder (actually Linkwitz-Cmoy) was the first I studied. Seems like I got it somewhere else. It was half a decade ago and my memory isn't the best in the world. So, did I get my definition of spatial distortion from Cmoy? Jan Meier?
1. Thank you for stating it that way. I leaves room for other opinions that disagree. For example, I can't see how reduction of separation enlarges the "sonic cloud". But you're welcome to have your opinion.1. In my opinion cross-feed does address too-close perspective and inside-the-head localization a bit. Not 100 %, but a little. It kind of enlarges the sonic cloud my head is in so that a lesser percentage of the cloud is inside my head and larger percentage outside. 2. I don't mind sounds inside my head just as I don't mind thoughts inside my head. 3. For people who don't want sounds inside their head my advice is: Don't use headphones! Use speakers!
Yes, certain tracks and recordings benefit from separation reduction, which is mosty what cross-feed does. Nobody's ever discounted that.I've experienced certain tracks to sound odd like certain sounds are compressed on the left and right feeds. Try some of the 60's recordings. I notice it with Beatles recordings.
I have also read from others state that some of the older jazz recordings needs crossfeed for headphones.
Yes, but all of that has to do with target response curve, not spatial distortion. But matching the response at the ear of a speaker at 45 degrees doesn't change where the image is placed inside the head with headphones.Also, a saw a video of tyll talking about target curves, and the resonances caused by under the chin neck curviture area, ear geometry, for the general target curve. The curves targetted for headphones is to come close to 45 degree speaker directions to the ears, etc.. As the speaker directionality changes the curve.
That in particular was interesting since, over ear heaphones and speakers runs into ear exterior geometry and speakers the neck area, etc.. Inears has just the effects of ear canals.
