Guidostrunk
Cheap LP up for grabs.
https://www.head-fi.org/threads/monolith-cavalli-liquid-platinum.938987/
That went fast, and the cheapest I have seen yet! Some people just don't know what they have.Cheap LP up for grabs.
Valvo (Rebranded Bugle Boy) Hamburg ECC82 Long Plate D Getters 56'
The have the acid etched code of K62 D6G. The K62 stands for 2 version of the Long Plate and the D stands for Hamburg Germany Plant (Valvo) 6 stands for 1956' and G stands for July. There are always going to be rebranded tubes, however acid etched codes always override what is painted on the tube, and you can find good deals this way.The pair of tubes look like 2 genuine Amperex Bugle Boys to me, since they have the Bugle Boy logo and were made in Holland. If they are Valvo, they would have been made in West Germany possibly.
But you know I haven't done lots of study on 12AU7 tubes.So can you explain why these are Valvo tubes, Wes?
Again, it is all about the acid etched codes, on the lower side of the tube, and I bet that Mullard has an acid etched code with a B in it for Blackburn, and the Amperex has a triangle acid etched on it to signify Holland.Cool, I know rebranding is quite common in tubes, but the pair of Valvo tubes really confused me
I've seen Mullard 12AU7 rebranded as Amperex, but it still has "Made in Gt. Britain" printed on the bottle, so at least I can know it's a British tube and it can't be an Amperex. I've also seen Amperex rebranded as Mullard, but on the bottle it says "Made in Holland". So I thought the Made in country should always be correct. But in this case the Made in country can also be incorrect....![]()
@cddc Take a look at this pair!
The one on left is a true Holland Bugle Boy the one on the right is actually a Hamburg Germany (Valvo) rebrand. The seller doesn't even know that one tube is worth twice as much as the other.
You can barely tell by looking at the plates, but I know what to look for. Look closely at the tabs that hold the plates together and you will see the Hamburg tube on the right has the tabs pushed through to the outside leaving a little bit of chrome finish showing. The Holland tube has the tabs pushed through to the inside. This might not makes sense and is hard to explain, so I recommend looking for acid etched codes. This seller doesn't show them in a pic, but list the codes in the description, and still doesn't realize they are different because they were made in different countries. I have studied thousands of picks and studied many in person, to learn all the subtle differences in the build structure, so I can identify the really special ones, and often have found deals on rebranded tubes.
