As an owner of the Liquid Links Conti cable, pairing it with bright or treble-hot IEM is the best way to go, from my constant experience in cable rolling trying different IEMs.
It is a fairly dark cable meant to relax/dial back the brightness of an IEM and also make the treble take a back seat.
It also give the sound a little bit of warmth.
Bass has a bit more body to it, but this depends on what you pair it with of course, so YMMV.
Midrange will be thicker but might lose a bit of detail depending on your source/music recording, due to the dark nature of the cable that again, put the highs on a step back.
To the trebleheads who love a lot of treble and energy, stay away from this one. But for those who yearn for a more relaxed sound and don't like their IEMs too bright, please give this entry level baby a try. It's fairly affordable and it's very very well built, with little to no microphonics from after nearly one year of heavy use at home and in my daily train traveling from work to home and vice versa.
A very nice daily driver.
P.S: This cable cannot tame every bright sounding IEMs, mind you. So if you got the Conti cable, please test whatever bright IEM you are interested in buying to see if it works for you before buying to avoid disappointment.
For example, I tried this cable to tame the hot treble on Phonix Vision Ears and it did very little to calm the intensity. Sometimes the treble just feel too much out of the stock cable. But this one -- while it work better than the stock cable in some degree, still couldn't tame it.
Always test before buying
