xkamran
thanks for your valuable input. so just to be clear. if i have nos disabled in r26 and using good quality external clock this will be beneficial?I have the R26 too. Its use of a R26 connected external clock with different inputs is a little more nuanced: always in play for asynchronous inputs (USB, LAN), only referred for synchronous (I2S etc) when R26 is doing oversampling (i.e. NOS off).Gustard clarified this over email. In my experience there’s definitely benefits from using a lower jitter/phase noise external clock as a reference for multiple devices, including upstream asynchronous ones like USB regens and switches. My view is that’s because each such device operates more precisely generating cleaner square wave output signals making the life of the next device in the chain easier, and so on down the chain. Not because they’re ‘in sync’ with the DAC at the end of the chain. [current case in point is the LAiV, no ext clock input but most definitely benefits from the upstream ext clocking I just described.. no ‘syncing’ there] Though I can imagine how syncing the sender and recipient devices of a synchronous data stream (streamer/DDC & R26) like I2S might be beneficial.
here is the funny part.
My source is computer connected to DDC u18 feeding by lhy clock ock2. Gustard r26 dac.
burson voyager to timekeeper GT3 and spendor classic 4/5 speakers. all of this is connected rto isotek aquarious.
when i disable the nos. anything which is pcm volume goes very low. dsd works fine. Using upsampling from roon
