What is the main difference in sound stage and quality between micro BL and Nano BL??
Lets talk about IfI Micro BL
- Thread starter headphones1999
maninthehighcastle
Hi. I'm using the idsd micro black for quite some time now. What i've noticed is, that if i have the dials just below 0 the sound appears to be only on the left channel and then after increasing the volume a bit on both channels. Is that something you can confirm or test? I use LCD2 and Aeon flow Open on normal gain.
kukkurovaca
- Apr 7, 2017
If you mean, there is channel imbalance at low volume levels, this is extremely common/normal with analog volume controls.
maninthehighcastle
Exactly. Ok. Thank you
crashtest33
Member of the Trade (Cable maker)
Has anyone got this iFi and a Vorzuge Pure2+ or Duo for comparison?
To me it does not make a lot of sense to compare a DAC/Amp with a pure amplifier.
The final sound of the combo with Pure 2 will be dependent on an external DAC/DAP.
And Micro is 8 times more powerful (4W vs 0.5W @16 ohm).
crashtest33
I was referring to the Amp stage pal. The iFi has a line out I assume. Do you own both?
No, never owned the Pure, just heard it in the past.
Basically, I was considering between the micro and the Pure II+ to amp my DAP but finally I made the right choice))
