- Aug 18, 2007
nice - My new Woo GES has the same type of finish and engraving and looks wonderful.
Originally Posted by Pars /img/forum/go_quote.gif This really looks nice Amb... love the design elements in the panels. For the Sigma22 logo on the front panel, did you have to use HPGL to do this? Or does FPE's software support those fonts and character sets, etc.? |
Originally Posted by error401 /img/forum/go_quote.gif Wouldn't the anodizing isolate the connection? I'm pretty sure aluminum oxide is an insulator. |
Originally Posted by amb /img/forum/go_quote.gif MASantos, any piece of equipment that contains AC mains voltage should have its chassis tied to AC ground. This is to protect you from getting a shock if any live wiring or component inside is to come loose and touch the case. The chassis would shunt the lethal voltage to ground (and hopefully blow the fuse and/or trip your house wiring circuit breaker). In this case, the body of the Schurter IEC is already connected to the ground lug, and it's mounted directly to the aluminum rear panel without isolation, so no explicit wire need to be added to make the chassis/ground connection. |
