audionewbi
- Jan 24, 2010
No idea, using mine now with DX90 & DT1350, simply a brilliant amp, still the best I have heard
How similar is it compared to your minibox amp board?
ciao Traveller user
Have you ever tried to use the traveller as. preamp? I tried to connect traveller with Fiio X5 into another amp. I am suprised by this combination. the setup can improve the details and especially soundstage.
however this combination sa a portable setup I know is a bit crazy. I just can't help to have a go with this recently down the street!
any idea if it is able to drive higher impedance cans like 250 ohm Beyerdynamics or 300 ohm Sennys like the HD600?
thanks
Hi,
I have cowon 1 which only takes supports optical out. i am planning to use it with my audeze el-8. does this amp support optical input. thanks
Get a xDuoo XD-01 for optical
Alex
