Lehmann Audio Linear
May 20, 2024 at 9:06 PM Post #16 of 85
I have read that Sennheiser used LehmannAudio Linear (pre-SE) in the development / tuning of HD600 / HD650.
May 20, 2024 at 9:08 PM Post #17 of 85
I have also read that they demo'd the HD800/HD800S at shows with the Linear.
May 20, 2024 at 11:47 PM Post #18 of 85
I took a screen shot of my soon to be my amp.
May 21, 2024 at 1:46 AM Post #19 of 85
True for the HD 800. When the 800S was launched in 2015 Sennheiser already had its own headphone amps in production, HDVD 800 and HDVA 600, since 2012.
May 21, 2024 at 1:58 AM Post #20 of 85
OK then. I will have to wait and check it out.
So, yours still works perfect? Have you replaced any capacitors or anything else?
I too was worried about the capacitors, but this amplifier has only been used for a few hours a year. I removed the cover and saw if the capacitors visually showed any deformation or swelling. Then I did several audio tests with the V200 (as a verifier) and 16 ohm Sony closed headphones. Closed-back, low-impedance headphones are like having a magnifying glass in revealing electronic problems or other anomalies. From how it has been used I would say that for 15 years or more, this amplifier will definitely not give any problems. That machine you see on the volume knob and the halo that left the paper handkerchief soaked in neutral liquid for glasses (first photo).👋:darthsmile:
May 21, 2024 at 11:18 AM Post #21 of 85
Anch'io ero preoccupato per i condensatori, ma questo amplificatore è stato utilizzato solo poche ore all'anno. Ho tolto il coperchio e ho visto se i condensatori presentavano visivamente deformazioni o rigonfiamenti. Poi ho fatto diverse prove audio con il V200 (come verificatore) e cuffie chiuse Sony da 16 ohm. Le cuffie chiuse e a bassa impedenza sono come avere una lente d'ingrandimento nel rivelare problemi elettronici o altre anomalie. Da come è stato utilizzato direi che per 15 anni e più questo amplificatore non darà sicuramente alcun problema. Quella macchinetta che vedi sulla manopola del volume e l'alone che lasciava il fazzoletto di carta imbevuto di liquido neutro per occhiali (prima foto).👋:darthsmile:
Cool. Have you ever thought about getting it upgraded by Lehmann?
May 21, 2024 at 5:39 PM Post #22 of 85
Sorry, I corrected the post above in English.
Yes, I knew about this update, but the sound signature of my old Linear is something amazing. With the V200 and the Linear I have two non-identical high-quality amplifiers.
May 21, 2024 at 7:08 PM Post #23 of 85
Got my tracking info today. Hoping on a Monday delivery.:fingers_crossed:
May 27, 2024 at 4:49 PM Post #24 of 85
Got my new amp today. Small, long and the lightest amp that I have bought in years. On a par with the Liquid Spark, I would say.
Nice, clear sound and pretty neutral. I was just finishing up a week with my HD660S2's and so I kept them going for today.
I gave been snapping pics today. Also played with the Schiit Loki a bit already. Can't wait to run all the headphones through this amp.
May 27, 2024 at 5:13 PM Post #25 of 85
My boy getting psyched up to put the amp through its paces. Good assistants are Hard to find!
May 27, 2024 at 6:18 PM Post #26 of 85
The 13th is definitely the year (2013)
May 27, 2024 at 6:51 PM Post #27 of 85
The marker is discolored, it looks like a 0.6A fuse. The correct fuses to insert are T 0.5A at 120V. Lehmann linear in Europe uses fuses from T 0.25A to 240V.
May 28, 2024 at 11:44 AM Post #28 of 85
I found a cheap Black Cube linear USB and just installed it, not using the DAC. Sounds a bit softer (tonal wise) then the ADI-2 DAC fs. RME goes deeper and is sharper, but the softer Lehmann offers a smooth listening and I like the combination with my DT 1990 a lot.
May 28, 2024 at 11:48 AM Post #29 of 85
... did your 'boy' get to set the DIP switches? 😹 [They are set in a way that's not diagrammed ...]
May 28, 2024 at 12:06 PM Post #30 of 85
No, at this point he was still psyching up. :smile:
Using this with my Arya's today. Starting with 0 gain and it sounds great. I will try a gain of 10 after several more songs.
Really crystal clear, with clear, clean music.
