Wow, I had no idea it was only 15 ohms. I think the lowest Hifiman I've heard of is 25 ohms?
Anyway, for such l low impedance headphone go with solid-state of low output impedance. Better off avoiding tubes unless you know which ones can output a lot of power.
I run my LCD-5 off of my TT2 as well as my iFi zen stack (depending what room I’m in). I have zero issues currently and did experience some light fatigue but no longer.
As everyone says, different strokes different folks and something about miles
The A90 is more than plenty to drive the LCD-5. I have an RME ADI-2 DAC that pushes my HE-500 (89 db/mW sensitivity, 38 ohms) to absurd levels, and that is less powerful than the A90.
I suggest trying out some EQ. If you don't have it already, try Equalizer APO and use some kind of Sine wave generator. The fatiguing sound you're hearing may very well be a peak in the treble somewhere. Try a sine wave sweep starting from 5kHz up to 20 kHz, and if you hear any sharp peaks, use EQ to filter it out.
If A90 were not current limited it would double in power with every halfing of impedance. I have no idea how much LCD5 can require in any given instance, including any instantaneous current draw requirement. But limiting current to a low impedance is not ideal let alone a big planar.
You guys are clueless. Numbers without any meaning and without a lick of understanding.
Your FOTM A90 can do 1.4A from the TPA6120A2. Your FOTM THX hard limits 1A. Everyone loves AHB2, HPA4.
It basically fixed the fatigue problem. It is great that it did, but it also makes me worried that there are even better EQ settings out there!
Also Dave's DSD and PCM modes change the sound dramatically, I really don't fully understand why, but maybe some of you can point me into the right direction.
