Originally Posted by Leporello
I'm not sure if I follow your reasoning here. (I certainly would like to hear XRCDs but they are very hard to find.) A cd version of a good analog recording is a result of digital technology, after all. Doesn't you example actually tell about cd's ability to preserve the quality of the input signal?
There is also the fact that you prefer those originally analog recordings to recordings made entirely digitally (nothing wrong with that, of course). To me this seems to suggest that the original analog recordings have something euphonic about them: pleasing but not necessarily accurate.
Regards,
L.
The flavour of a recording has far more to do with the original format it was captured on, than the final format it ends up on. An Analogy: Why are effectively all high-end tv commercials and top tv shows shot on film (which is WAY MORE expensive), despite the fact they will all end up on digital video? Because the final result is SO MUCH more pleasing when initally captured on analouge. In the visual realm, there is hardly even a debate about which is a better aquisition format when you can see the difference before your eyes (star-wars-george-lucas fanboys excluded).
It takes an incredible amount of talent to shoot on video and make it look half as good.
It is the same for audio (but audio is far more harder to quantify) - recordings initally captured on analogue will be most likely far more aesthetically pleasing..even on cd!! As far as accuracy goes - what makes you think the digital is a more accurate aquisition?
Why do I think analogue is a better aquistion format? Firstly, distortion in analogue is harmonic (just like in your ears, in music intruments like a trumpet for example, and in nature). Distortion in digital is not harmonic. There is no equivalent in nature, and it is far more destructive to the timbre of the music (even when there's a lot less of it). This is why you can't overdrive digital (you can but it sounds like crap). Analogue has headroom (digital does not), and blooms, compresses or overdrives far more naturally than digital. Digital has to be brutally peak limited so it does not clip as clipping in digital sounds so incredibly bad - so goodbye to your natural transients! Largely, because of this ability to tolerate overload, the response of analogue follows a natural response curve similar to your ears (or eyes).
Once the sound is down on tape, however, digital does a far better job in copying the signal than it would do in the inital recording (because the HUGE original bandwidth of nature has been conveniently brought down to a manageable size by the natural compression of the analgue tape (as opposed to the artifically applied compression/peak limiting of digital). Now the digital can capture the 'natural' response of the analogue (with the 'natural' overdrive and all!) far more effectively without the problems of digital clipping/overload.
BTW the best analogue studio tape in wide usage will capture up to 50kHz of audio information. Also, digital is only lossless when copying directly. Do anything to the signal (an effect, a mix, a volume change, a change of sample rate/bit depth etc) and you are resampling - ie losing information forever.
This is why this news is such a potential tragedy.. Even if you only exclusively listen to cds!
