]eep
Obviously volume control is not a must in the literal sense. It's a choice. Or an option. But a dac is a dac. A digital to analog converter. Not a preamplifier obviously. It would be if you could add a few purely analog inputs. I also hate it when there's a volume control on every box in the chain. I have now a streamer with dac, a HP/preamp and two mono amplifiers all with their own volume control. I wouldn't call that a purist solution. Because everybody demands a volume control... Great for troubleshooting; " I don't have sound! Why don't I have sound?"I disagree
Modern digital attenuation is being done on 1, max 2 bits. And the majority of the DACs are not using the full 24 bits, but only 20, or 21. So plenty of bits left to execute proper attenuation. And this will be the best and most transparent volume control you can have. If you only have 1 source, and the imput impedance of your amp is high enough, absolutely no need of a preamp (or you like the distortion/coloration the later is adding...)
It is very sorry the LAiV has no volume attenuation. I could live with Coax imput, but volume control is a must in a modern DAC
Like I said, if you want to do high end, let the engineers make their own decisions. It's always matter of choosing the compromise that you think will yield the best results. That's with a resistor ladder or even better: don't attenuate at all. Isn't it kind of stupid to reduce the volume first and then pump whatever you have left with full force to maximum output? What is the logical thing to do is; make an amplifier with variable amplification. Not variable attenuation followed by maximum amplification.
A dac is just a source. One source. And there are more choices than one. And not all are digital. So if you want a modular solution instead of an all-in-one or combined devices (amps with mediocre integrated dac or DACs with integrated mediocre HP amp or turntables with integrated crappy phonostage etc etc) you do it right and put only one high quality solution in one place.
But as I said: those are all practical and philosophical choices. Laiv is producing a complete chain and they make the choices for the best result. So far they seem to be on a roll. For us to choose which components we want to build our system.
