I'm going to wager that this is the very first time in Head-Fi history that those words have been spoken.Sorry I am about to get in a submarine, I'll answer re regulators and Stereomour when I resurface.
L0rdGwyn's DIY Audio
- Thread starter L0rdGwyn
Xcalibur255
- Feb 4, 2008
Museum ship or working? Both sound fun.Sorry I am about to get in a submarine, I'll answer re regulators and Stereomour when I resurface.
- Jan 15, 2015
Probably a working sub, since @L0rdGwyn mentioned he is cruising through the BahamasMuseum ship or working? Both sound fun.
@cacacacaciiiiii on the Stereomour, you could use it as a headphone amplifier, in fact I'm pretty sure this specific question has been asked in the Bottlehead forum. It isn't necessarily ideal however as the output transformers will be tapped for speaker impedances, I think the sound would be better if dedicated headphone transformers were used and you will lose power output this way. My guess is you would get better performance from a dedicated headamp like the Mainline, but I can't be certain. IMO, any headphone amp using DHTs should use a DC filament supply, so you would want to include that. I would check the Bottlehead forum for this specific question, I'm sure it has been asked.
Paladin79
Previously MOT: Cables For Less
I have decided to make my own plinth for a TD 125, considering what they are fetching with decent tone arms it will be a nice small project. I have a few projects before that but I like to plan ahead.Here are some other random things I've acquired recently.
Custom walnut plinth for my turntable. Just waiting for my new tonearm at this point, then I can rebuild it.
A pair of Sowter I/V transformers for my PCM63 DAC build. I've sort of changed mindsets for this design, I was originally looking to do a simple passive I/V transformer coupled output. I'll likely still give that a try, but it has compromises. What I'm more keen on doing now is another tube output stage using E182CC with transformer coupled outputs. TBD.
A very nice quad of NOS graphite plate 801A. I paid around $105 dollars for this set, plus international shipping. Absolutely ridiculous deal.
I have decided to make my own plinth for a DT 125, considering what they are fetching with decent tone arms it will be a nice small project. I have a few projects before that but I like to plan ahead.
Cool! Always good to have more plinth options out there, please post some pics when it's done
Paladin79
I shall, I will also make a custom arm board of course. That is pretty simple stuff.Cool! Always good to have more plinth options out there, please post some pics when it's done
I've also been scheming another project, as I said I can't help thinking about tubes on vacation...
I am considering a strictly community DIY project, a spud design. I have prototyped similar circuits and the sound is very good. However that was done with the Sowter 8665 parafeed transformers. The wait time for Sowter is very long and frankly they aren't what they once were since being sold to Carnhill. The 8665 are a little pricey too and require a somewhat complex switch to adjust the turns ratio...
So I've reached out to Jack at Electra-Print to commission a pair of headphone parafeed transformers along with my intention to create a DIY project, meaning potential future orders from others. If he can provide and my plans look good, I will look to release it on Head-Fi.
That would mean PCBs, BOM, chassis CAD files, build instructions, etc. The trick will be making it inexperienced DIYer friendly and using easily sourced parts as it will require semiconductors. TBD, we'll see what Jack says, he can be somewhat particular about his orders.
bcowen
Did they let you drive? Or at least fire a torpedo?A working one! At least that's what they told me before I got on...I survived!
Here is a green moray 75ft below
Nope, I just sat there looking out the window at the reef, pouting. Turns out they don't want some tourist crashing the sub into the coral reef for some odd reason.
This sounds awesome man! Looking forward to hearing more about it.I've also been scheming another project, as I said I can't help thinking about tubes on vacation...
- Jan 15, 2015
If / when you look for guinea pigs, to try out building your kit - I am in!!That would mean PCBs, BOM, chassis CAD files, build instructions, etc. The trick will be making it inexperienced DIYer friendly and using easily sourced parts as it will require semiconductors. TBD, we'll see what Jack says, he can be somewhat particular about his orders.
Thanks yeah I will post here as thing take shape. Once I confirm I have a source for the transformers I'll figure out the details. Would be a dual mono power supply, CCS loaded spud circuit, parafeed output, likely Clarity Cap parafeed capacitor, LED biased. I will subjectively test several LEDs to find the best. I need to decide what direction to take the CCS (FET vs BJT vs current source IC) and make setting the current simple and low hazard. Likely the supply would not require regulation given the high PSRR of the output stage, which would simplify things considerably.
Mr Trev
Bonus points if you can make it a (reasonably) cheap Chi-Fi killer. I remember watching an interview with somebody in the auto industry talking about how it was easy to make a cost-no-object luxury car, but it took serious talent to build a stand out econobox. If you can apply that to the audio realm…Thanks yeah I will post here as thing take shape. Once I confirm I have a source for the transformers I'll figure out the details. Would be a duo mono power supply, CCS loaded spud circuit, parafeed output, likely Clarity Cap parafeed capacitor, LED biased. I will subjectively test several LEDs to find the best. I need to decide what direction to take the CCS (FET vs BJT vs current source IC) and make setting the current simple and low hazard. Likely the supply would not require regulation given the high PSRR of the output stage, which would simplify things considerably.
Total: 8 (members: 0, guests: 8)
