It's a beautiful looking amp in this picture of the completed amp. Are the feet still missing?
I don't like feet on my personal amps, but I will add them for future builds. I might even add them to this one.
Oh why don't you like feets on your own amps?
My amps are arriving, probably today.
Sowter I/V transformers arrived today.
My eyes lit up at the mention of Sowter. Huge respect for them now with what I'm hearing from Odyssey. What's an I/V transformer?
I have heard of those…they are the DAC chip itself, right?Got some Korean and Japanese made PCM56P-K to try out.
It's a bit technical but here is what it is!
Many of these old R2R type DAC chips are "current output" types, meaning rather than outputting a voltage that can be amplified directly (by a following preamp, for example), the output is a small AC current. This current needs to be converted to a voltage signal that can be amplified. Many of these chips have built-in circuitry to perform this function (often times opamps directly on the chip), but better performance can be achieved using a dedicated current-to-voltage (I/V) stage.
There are lots of ways to do this, the two major categories are active and passive.
Active I/V stages typically use opamps, transistors, or even tubes to perform the I/V conversion and simultaneously amplify the signal.
Passive I/V stages often use resistors to perform the I/V conversion, then the signal is amplified to line level by a following amplifier stage. The less common passive approach is to use a I/V transformer, less common due to the need for specialty transformers and expense.
So, these are I/V step-up transformers. They convert the AC current output of the PCM56 DAC to a voltage and simultaneously provide some voltage gain across the transformer. The signal on the secondary of the transformer will be amplified by an additional tube gain stage to reach 2Vrms output with a suitably low output impedance.
Transformers have other advantages compared to resistor I/V - they have a built-in low-pass filter due to the transformer bandwidth which will remove high-frequency quantization noise from the output signal (if using a resistor, an additional low-pass filter must be added in circuit). Another advantage is galvanic isolation between the DAC PCB ground and the secondary ground - keeping the grounds separated will reduce injection of noise from DAC circuitry into the output stage ground.
Low noise is a top priority, so we'll see how we did when I throw this thing together.
