mordy
- Aug 8, 2010
Thanks. According to my understanding the safety circuit shuts off the amp in the event a tube short circuits in order to prevent damage to the amp and headphones/speakers.I can't speak to how it was set up in Glenn's OTL. I believe one of the other amps you are referring to is a Feliks Audio amp, they list a "preamp safety circuit" in their feature list, likely for the reasons I listed above, to protect against DC transients given that the two outputs are in parallel, the reason both are on at the same time. It isn't something I am interested in incorporating into this amplifier, but sounds like what you have is well-suited for your listening needs.
I know that this safety circuit works because at one point I received a defective Chinese adapter that shorted out a power tube and it prevented the amp from blowing up - unfortunately a fate that befell another amp where I tried the same adapter. (Did not understand where the problem was at first.)
