To the naked eye that transformer winder looks very well-engineered, would be an incredible resource to have. Amazing speakers, I'm sure there would be high demand for a miniaturized version. Sounds like the makings of a profitable albeit niche business venture
It is definitely a sight to behold. He has a couple videos on his channel where he shows more angles and features. The real takeaway is the wire tensioner. Everything else is fairly straightforward. To give some perspective, some wire tensioners being sold for transformer winders are friction based devices. They actually have a drag wheel that pinches your wire. This can work, but you risk damaging the insulation layer of the magnet wire.
The better wire tensioners will work by providing feedback to a motor that will let wire go from the spool at a very particular rate, however, they cost several hundred if not thousands. This guy's feedback mechanism is that little cart connected to the spring with a piece of linear tape to the side to monitor the position of the cart. This is actually how a printer works and most of these parts can be sourced from a scrap printer to make the cost of the project a lot cheaper while still maintaining a very high degree of accuracy.
It's pretty freaking ingenious. His design can also be made for a lot cheaper too. I get the feeling that his machine is built the way it is because he had a lot of those parts on hand. If you ditch a lot of the gears and belts by making all your motors direct drive, it should reduce the cost by quite a bit.
The ONLY modification I would love to make is replacing that spring on the cart with a load cell or a load cell and a spring. That way I can know the amount of tension I put on the wire and dial it in for best performance. Other than that, this machine is probably about as good as it gets.
I might end up sending you a few practice transformers for you to test considering you have more test equipment than I do : P
The speaker is a very different story. It's one thing to build that speaker. It is a completely different thing to figure out how to make it in such a way that it is easy to produce.
The real achievement will be making a smaller than average mid range horn. That KS-6368 horn on top of the speakers I linked there is nearly flat at 220hz. I want mine to be flat at 300hz, so I should be able to downsize it a bit. That horn is about 16x11 at the mouth, and I am really hoping I can get away with 12x9. If I have a 12 inch wide horn on top of a 12 inch wide woofer cabinet with a 10 inch woofer, it should work out to being just a bit bigger than the snells with better bass extension and much better mid clarity.
Definitely on the large side, but also doable for a large desk speaker. Or so I think.
