littlexx26
I am going to put 575X. How much solder paste I should use each point?
Just for the record, Whitigir, is this what you are using? And is it simply a drop in replacement (with due deference to the size difference, for the factory clock? Thanks.
https://www.mouser.com/ProductDetail/ABRACON/AOCJY1-100000MHz?qs=E5sDuDyvt8R6wCADPuHK9w==
Out is 950x and in is OCXO as @b0bb recommended. It is dropped right in on the DIL-14 style without any soldering Q_Q woaaa...rolling clocks Instead of Tubes ? Lol
This clock here is 50PPB (per Billions) ! In contrast of 950X which is 25PPM (per Millions)
https://www.mouser.com/ProductDetail/815-AOCJY1-100M
It is what I am using now . However ! It isn’t a simply drop-in. My version of lks004 I was able to modify some parts and make it possible
in order to drop in, you need to have a DIL-14 socket installed like what I showed in the pictures. It also consumes 1A of power, so you need to make sure that your voltage regulator is up to task, if it is, then you also need to modify the capacitors as well. Only some few first batches of lks004 is using these Texas regulators TPS7A4700. Otherwise, you will need to also upgrade those regulators and so on. But doing that much work, you may as well look into Pulsar OCXO which is much better and is ready to drop in if you already have a DIL-14 socket installed
So, for the lower power regulators on the newer 004, it is more likely that you need to look into either Pulsar, or the 575X or the 950X
Some soldering requires to replace the capacitors and to put in the DIL14 dip socket. You need to make sure that you have the powerful regulator first though. Take pictures of the regulator closeup and we can identify itWOW! - great work! No soldering?
Capacitor is here
https://www.mouser.com/ProductDetail/647-RNS1E470MDN1
Clock is here
And wow, mouser us had 5 in stock and today is only 2 lol....
The DIL14 can be found here . Scroll to bottom pace and pick $8.50
http://www.twistedpearaudio.com/digital/cronus.aspx
You are welcome , and smartphone pictures shall be good enough ? Yeah, if you have the DIP socket, it is dropped inThanks! When I said soldering I just wondered if the ocxo just pushes into the dip14 socket? I realise the socket itself & caps need to be soldered though - LOL!
I will take close ups WHEN I GET A NEW CAMERA, dropped mine and broke the battery cage cover 'clean off'! It was old anyway (reads ancient!).
Many thanks friend!
you've answered the question! before I even ask! I was wondering about the comparison to r2r7 myself actually.Also, if you remember, I built my Pinkfaun I2S PC, and I was unable to observe the improvements on LKS004 where as my r2r7 improved to another tier. Upgraded this 100Mhz clock and the LKs004 is now scaling up with my Pinkfaun I2S. It is so awesome!
https://www.mouser.com/ProductDetail/815-AOCJY1-100M]
