First, these are op amps, so DC current or/and voltage are fine. Don't worry.
Second, ESS DAC
each pin of complementary current output (D1 and D1b in Figure 1 of datasheet) has a current offset, that is a bias current.
The VCM (Vcom) bias voltage that is common to both I/V transimpedance amplifiers
(U1, U3 Figure 1 ESS datasheet) is used to cancel out these current offsets.
This is the job of VCM (Vcom) !!!
That is why the Vcom capacitor has such a profound influence on the DAC's sound.
That is why this Vcom voltage reference must be frequency independent.
A large Vcom capacitor causes these common bias currents to trickle downstream.
I have worked out the details, be happy to post if interested.
Now the numbers, from the datasheet:
At idle, ESS DAC has an "current mode offset" of ~9mA per pin. ~18mA total.
Multiply this idle current with Rf=68.1 Ohm I get 1.24V, which is in the ballpark
of VCM (Vcom) that I measured. With Rf=61.9 Ohm I get 1.13V which is a bit off.
So there might be something details that I am not aware of.
Third, resistor R6 is connected to VCM.
By superposition priniciple,
it is easy to see a VCM term emerges from DAC1,
given any ideal/perfect difference amp.
Why is VCM there ? My guess is: the complementary outputs D1, D1b may not be
perfectly balanced. VCM is connected to R6 just in case ???
This is as far as I want to go in this Vcom study, really enjoy the discussions. Next study is jitter....
