It is not "my mod", I posted the mod in #3332 for Tiago.
@tiago please join the discussion and share your impression of this mod.
The RC that I was referring to is the Time Constant to replenish the voltage due to leakage.
See diagram.
Vcom ideally should stay constant. Practically it is performed by the (equivalent) resistor R and capacitor C.
I don't know why these values were picked.
RC values are a scale factor, the actual impedance is determined by the frequency
Merely looking at RC values means missing a big chunk of what is actually going on.
If you want to implement some of the changes from the 005, at least get the detailed pictures to understand what LKS did.
The blurry marketing photos should not be used as any form of reference
All we are able to see is the 0.1uF.
Do you even know it is the Vcom cap without evidence of the physical connection from the trace on the board?
I know nothing about op-amp frequency compensation.
I agree that the input impedance of both inverting and non-inverting inputs should not be varied too much.
But this is not possible due to frequency dependency of the impedance of Vcom capacitor C.
That is why Gen1s have the 22ohm resistor, impedance never drops below 22ohms.
The way you have drawn things is definately not the case in the Gen1 board.
If you want to mod why not do this mod instead?
The 150uF wet tantalum cap mod also modified the input impedance by 15x too.
That is what gives you the extra bass extension.
Capacitor reactance increases with falling frequency, it becomes less effective with lowering frequency
With 10uF//5k, the reactance is 3 ohms at 5000Hz (most sensitive frequency band of human hearing)
With 150uF//5k, the reactance is 3 ohms at 350Hz
3ohms is the min ESR of the cap so its reactance never falls below 3ohms.
Below the frequency where the reactance hits 3 ohms the bypass becomes less and less effective as rectance rises, the lower you go in frequency range.
This means the bypass operates up to a frequency 15x lower without the penalty of crazylow reactance at the higher frequency upsetting the I/V balance too much.
(It works better if you have the 22ohm in series, it then becomes 25 ohm instead of 3ohms).
This is why the tantalum caps work as well they do, the 150uF extends bypass down to 350Hz compared to stock which starts to become in-effective at 5kHz
This is the reason the low midrange and upper bass performance on the 004 is lifted.
What is the spectrum of frequency of this Vcom capacitor C subjected to ??? Do you know ?
The output of the DAC is a sequence of sigma-delta spikes (I could be totally wrong here) which
may have all kinds of frequencies. This is my guess.
Depends on the sampling frequency typically 22MHz, the main impact is on the audio signal not the sampling noise as the impedence rises as the frequency falls.
At 22MHz the cap has effectively removed the resistor from the signal path, very undesirable as it unbalanced the I/V.
Gen1 used a 22ohm to isolate the opamp input.
