AuxInput
- Oct 4, 2011
Looking at my USB Audio Board - it looks like there is rectification being performed. Unless I am being naive here.
The black/red wires are coming from one of the two main transformers and just supply A/C at a lower voltage level. Yes, you are correct that there are rectification and voltage regulator on this card. This is essentially the power supply card for the USB input. The USB card should be mounted directly underneath this.
b0bb has had success in installing a separate small transformer for powering this USB board. I can't remember what specification he used. But you will need to wire that into the main power switch so that power gets switched on. I tested my USB input and I like the BNC coax input a lot better. However, I'm driving it from a crap motherboard. The JCAT USB card is on my future list.
I don't know how good this usb input is. I don't know if you want to spend a lot, but a USB interface might be a lot better. Options are the Singxer SU-6. Audio-gd has the DI-20 and DI-20HE, both which look excellent.
